Revell snow speeder diorama
If it doesn't exist..........yet
Astaroth
Post by Astaroth »
Hey everyone. As a little distraction from my sci-fi SiG entry I started a new project. Unfortunately I didn't take photos from the very beginning, which is the reason why I'm posting it in the wip section and not entering it in the SiG.
The model is Revell's tiny snow speeder. The molding and fit are quite good, just like all of those small kits. (I've already built two of them: Tie Fighter and Tie Interceptor)
Here is a first dry fit of the cockpit and the upper hull.
During the building of this thing and while watching Ep. 5 again, I got the initial idea to do a diorama out of it.
After discussing the idea with Stuart (Primus1), he practically forced me to go through with it. :D
So, this is the scene I will build, but we'll get to that later.
Of course the build started with the cockpit. I didn't do anything fancy here.
It was primered with black Ultimate primer, slightly drybrushed with silver and then I gave it
a wash with overthinned Vallejo MA USAF light grey (to kind of simulate the Ultimate concrete wash, which I don't have).
The pilots where primered by hand (Ultimate grey primer) and then hand painted. That could have gone better,
I just don't have that much experience with figure painting.
The cockpit was finished up by Vallejo brown wash on the pilots to rough them up a bit.
Next was masking the canopy. This also could have gone better. I scratched the clear plastic
on a few spots when my hobby knife slipped. But like every other mistake I make on this model,
I will use it to my advantage in the end. :lol:
The building stage is now finished. I had to use some filler on the bottom where the two hull parts meet but
that was entirely my fault because I forgot to remove some ejection marks that prevented a tight fit ... :think:
I then covered up the cockpit with some tape and now it's ready for primer.
All primered up with Ultimate black primer. And it's true, what they say: everything looks badass in black primer. :pistols:
For the color coat I wanted to try something new. I used "black basing" a couple of times before as a simple preshading without
overdoing panel lines. But for the snow speeder I want to do a really worn look and get more tonal variation in the top coat.
So I started to do a marble coat with very thin paint and low pressure and working really close to the surface. That might have worked
better with laquer paint or properly thinned tamiya paint, but all I had available was the same Vallejo model air USAF light grey
that I had already used as a wash on the cockpit. I thinned it with Ultimate thinner roughly 50/50 but that led to tip dry very fast so I
had to wipe off the needle nearly every 10 seconds. Due to the tip dry the spray pattern is not consistent over the whole surface.
Next time I will try to use a bit of retarder in the mix.
If anyone has a tip on how to use Vallejo model air for this kind of "detail" work (i.e. spraying small and in thin coats), I would be glad to hear it.
BTW, I used my H+S Evolution with the 0.2mm needle for this.
After I had the surface covered I sprayed more coats with the same paint until I had the coverage that I wanted.
And that is also where the model itself stands for now.
In the meantime I did some layouting for the diorama and prepared a base for it.
Here's a rough mock-up of how it might look in the end.
Now I need to do some experimenting and finding a way to properly represent snow and smoke.
Thanks for looking. :hi:
Primus1
Re: Revell snow speeder diorama
Post by Primus1 »
Excellent write up so far, its gonna look fantastic pal, such a recognisable scene and im sure you will do it proud.
What do you hear ? Nothing but the rain
Looks like this'll be a cool display (no pun intended,lol!) good luck with it buddy!
Astaroth
Post by Astaroth »
Primus1 wrote:Excellent write up so far, its gonna look fantastic pal, such a recognisable scene and im sure you will do it proud.
chief5437 wrote:Looks like this'll be a cool display (no pun intended,lol!) good luck with it buddy!
Thanks a lot guys.
There will be a lot of experimenting involved as this is my first diorama attempt. But I will do my best to make it look cool.
Astaroth
Post by Astaroth »
Today I started work on the diorama base.
I put on a first layer or air drying modelling clay.
Then I wrapped the model in plastic wrap and made an imprint in the clay where I want it to sit later on.
I know, it's not very impressive right now, but as soon as that clay is dry I will build up the landscape some more using either more
clay or paper mache (not sure yet, what will give the best results).
Thanks for looking guys.
Astaroth
Post by Astaroth »
Ok, now it gets interesting. :dance:
I damaged the model ... on purpose. I want to simulate the impact damage to the front left side from when the speeder crashed into the snow.
Maybe I should have done that before priming and before I painted the bottom. :think:
And remember: boiling water is not hot enough to soften styrene to a level, where you can tweak it really well. :naughty:
I let it soak a bit in the hot water and then gripped the front part with a pair of pliers and tried to bend it to shape, but unfortunately it ripped at a couple of places.
I really like the overall shape of the damage, so I think with some clean up, I can work with that.
I started by filling the largest gap with some thin sheet styrene. I'll let the glue dry and then do some sanding, more filling and sculpting.
Some more styrene added.
I really hope that this will work out the way I imagine.
Astaroth
Post by Astaroth »
Next update:
I cleaned up and resculpted the impact damage. I used Apoxie sculpt to fill and reshape the part.
Here it is with a first coat of primer.
While that was drying, I worked on the canopy. I want do display it partly open, so I separated
the front and back. That took a lot of work with saws and a knife. The canopy is very thick at the back
and the shape I tried to cut was not the easiest (going around the molded "hinges"). And of course close
to having cut through everything, the back window broke completely. :shifty:
No problem, as in the movie scene, the back window is completely shattered. :mrgreen:
Next I reglued it in a slightly open position and reinforced the connection with a strip of styrene.
And here you see the progress so far from a few different angles.
I would love to hear your opinion on that, positive or negative. I can take critique. ;)
I like it, but the cannons are a little crooked ;)
Good to see someone do a different take on this kit
I have the perfect music to accompany you as you build this
[youtube]VdWJPkVhWzo[/youtube]
Astaroth
Post by Astaroth »
Thanks, Scott.
Originally I wanted to do just a quick weekend build of that thing. Now it has turned into a constantly mutating
monster. There's always some new crazy idea creeping up. I will hopefully post one of those later on.
Heh, sometimes you just gotta listen to the kit and go big. This is awesome.
Astaroth
Post by Astaroth »
Thanks buddy.
I really enjoy this, although I feel a little guilty for not working on my Sci-Fi SiG build. :?
Primus1
Post by Primus1 »
You already have a massive seal of approval from me but this is turning into a very cool build ! I love that its progressing of its own accord and your just rollin with the punches, great job.
Astaroth
Post by Astaroth »
So the first crazy idea is almost done. I will post photos of that later on.
But the next even crazier idea is already in the planning stage ...
Astaroth
Post by Astaroth »
Finally finished up the next part of this build.
Reviewing Ep.5, I found a scene, that I liked even more. The moment, when Luke grabs his light saber before the
speeder is smashed by the AT-AT.
This meant, that I could not use the pilot figures I had painted before. Instead I decided to to some
plastic surgery (pun intended!) to a spare figure I had from a second kit.
I cut off the legs and arms and rearranged them to closely match the pose in the reference.
And propped against the speeder.
And here is Luke in all his badly painted glory:
And lastly how it might look in the end (unfortunately still without paint but a lot of dust on the speeder)
Thanks for looking, guys. Stay tuned for the next episode.
I think that is pretty darn good :thumb2: Awesome photo scene to use as inspiration
Love you were able to modify the figure to suit your needs
I use a really fine black pen to outline details on figures..like Luke's leg belts.
I cannot paint as straight as a permanent felt
Last edited by Twokidsnosleep on Tue Sep 06, 2016 7:36 pm, edited 1 time in total.
That's...that's just awesome. Great work on sawing a Jedi in half. I can't wait to see more!
Astaroth
Post by Astaroth »
Thanks Scott and Jason, I really appreciate your comments.
There is still one important part, that I have yet to make to complete the scene. And I'm not speaking of the snow. ;)
I won't go into detail yet, I'm not sure that I can pull it off...
I am hoping it is the smoke...got some ideas if ya need, but will keep my mouth closed until asked ;)
Astaroth
Post by Astaroth »
Of course there will be smoke. But that's not what I was talking about.
And ideas are always welcome, if you'd like to share. :-)
Amishhitman13
Post by Amishhitman13 »
You going to fab a big AT-AT foot? That would be awesome
I'm sorry miss most of this build, some very nice work so far, will keep a eye on it from now on :th:
Astaroth
Post by Astaroth »
Amishhitman13 wrote:You going to fab a big AT-AT foot? That would be awesome
Indeed that's the plan. :dance:
privatepete wrote:I'm sorry miss most of this build, some very nice work so far, will keep a eye on it from now on :th:
Thanks Pete. :)
panzerman825
Post by panzerman825 »
Cool idea for a Star Wars diorama. Some nice scratch building too. Awesome crash damage done to Speeder.
Bill
Return to “Sci-Fi”
