In the late 1950s, the Royal Navy operated the piston-engined Douglas A-1 Skyraider from its aircraft carriers in the AEW role. However, the Skyraider was a design that originated during the Second World War. It entered service with the RN in 1951 but, owing to its World War II vintage, would be considered obsolete by the late 50s. As a consequence, the Royal Navy issued its directive AEW.154 to begin planning for a replacement for the Skyraider. The aircraft considered most suitable for this were seen as those already under development for the Navy's GR.17/45 Specification for a new anti-submarine aircraft, of which the front runners were the Blackburn B-54/B-88 and the Fairey Type Q/17. In this competition, it was the Fairey Aviation aircraft that proved the winner, eventually entering service as the Gannet.
The intention was to use the Gannet as a stop-gap measure prior to the acquisition of a new, purpose built system intended to be used on the planned new generation of aircraft carriers. As a consequence, it was intended to undertake as little in the way of modification as possible - the AN/APS-20 radar from the Skyraider would be mounted in a radome under the fuselage of an ordinary Gannet AS.1, with the associated electronics and space for two operators inside. However, the size of the radome meant that the existing airframe was too close to the ground to accommodate the radar, and so a significant modification to the fuselage was required. This involved removing the observer's cockpits and creating a new cabin within the fuselage; this was accessed via a pair of hatches next to the trailing edge of the wing, which also meant that the exhausts had to be moved from this position to the leading edge; increasing the total area of the vertical stabiliser to compensate for the instability caused by the radome; and extending the length of the undercarriage to increase the clearance for the radome, which consequently increased the aircraft's overall height by 3 ft (1 m), and gave the aircraft a more level stance than the anti-submarine version. Such were the extensive modifications required that, in December 1954, it was suggested that the AEW version be renamed as the Fairey Albatross, as it was to all intents and purposes a completely different aircraft from its ASW predecessor. As it was, by the time the Gannet AEW was entering service, the ASW version was in the process of being replaced, avoiding any potential confusion.
The prototype Gannet AEW.3 first flew in August 1958, with carrier trials taking place using HMS Centaur in November, and the first production aircraft delivered in December. By August 1959, 700G Naval Air Squadron was formed as the Trials Unit for the new Gannet. This unit put the aircraft through an intensive test programme to make it ready for operation service, a process that lasted until January 1960, at which point the unit was renamed as 'A' Flight of 849 Naval Air Squadron. 849A Flight was then declared operational and was embarked for the first time in HMS Ark Royal. A total of 44 Gannets were ordered for the Royal Navy to replace the Skyraider (good luck finding after market decals for that!).
The Royal Navy developed its tactics in regards to airborne early warning using the Skyraider, and evolved them with the increased capabilities of the Gannet, in that aircraft had observers trained to interpret the information coming in from the onboard radar, and use it to control either the combat air patrol to intercept incoming strike aircraft, or alternatively direct its own aircraft to strike and attack a target.
However, due to the quality of the equipment, the Gannet had limited command and control capability, built as it was around the AN/APS-20 S-Band search radar and AN/APX-7 IFF set, connected to the AN/ART-28 Bellhop datalink. The datalink would transmit the information received through the Gannet's onboard systems to the operations room on the aircraft carrier (or whichever ship was charged with directing the Gannet's operations), which would then act accordingly to any threat presented. However, the Gannet had no on board processing equipment, which meant that the observers had to interpret the raw radar signal.
The Gannet had a three-person crew, consisting of the pilot, located in the cockpit at the front of the aircraft, and a pair of observers in the cabin in the fuselage, accessible via a hatch next to the trailing edge of the wing. The aircraft had a typical endurance of 5–6 hours and a maximum altitude of 25,000 ft (7,600 m). The Gannet tended to cruise on just one engine of the Double Mamba powerplant; alternating between the two engines every half an hour.
The sole operational Gannet squadron, 849 NAS had over the course of its time operating the aircraft a total of four operational flights plus the HQ flight. The HQ flight was stationed at three Fleet Air Arm air stations over the period of Gannet operation, while the majority of the operational flights were assigned to more than one aircraft carrier over the course of the Fleet Air Arm's use of the aircraft, with five RN carriers operating Gannet AEW flights.
HQ Flight - RNAS Culdrose (1960-1965); RNAS Brawdy (1965-1970); RNAS Lossiemouth (1970-1978)
A Flight - HMS Ark Royal (1960); HMS Centaur (1961-1963); HMS Victorious (1963-1967); HMS Hermes (1968-1970)
B Flight - HMS Victorious (1960-1962); HMS Hermes (1962-1967); HMS Ark Royal (1970-1978)
C Flight - HMS Hermes (1960-1962); HMS Ark Royal (1962-1966)
D Flight - HMS Eagle (1964-1971)
Each flight operated four AEW aircraft with a Gannet COD.4 for ship to shore communications. These flights were regularly deployed from the large aircraft carriers then in service with the Royal Navy. Additionally, it was intended that the Gannet would initially be deployed from the planned CVA-01 aircraft carrier, until the entry into service of a purpose built AEW aircraft. However, in the mid 1960s the British government brought in a series of defence cuts that led to the new carriers and their AEW aircraft being cancelled, and the phased withdrawal of fixed wing aviation in the Royal Navy. 849C Flight was disbanded in 1966 following the reduction of the carrier fleet to four ships with the withdrawal of Centaur for conversion to a commando carrier (which did not take place) and the decommissioning of Ark Royal for her major, three-year reconstruction to accommodate the McDonnell Douglas Phantom. Subsequent carrier withdrawals led to the disbanding of 'A' Flight in 1970 (when Hermes was withdrawn for conversion to a commando carrier) and 'D' Flight in 1972 (when Eagle was decommissioned). The final operational Gannets were operated by 'B' Flight aboard Ark Royal following that ship's major refit and recommissioning in 1970. The Gannet continued in service until the final decommissioning of Ark Royal in 1978 - a Gannet of 849B Flight was the last aircraft to be recovered by the ship on Saturday 18 November 1978. The withdrawal of Ark Royal meant that there was no longer a platform available in the Royal Navy to operate the Gannet, and hence 849 Naval Air Squadron was disbanded in December 1978, leaving the Royal Navy without embedded airborne early warning.
The phased withdrawal of the Gannet AEW, as part of the draw-down of fixed wing aviation in the Fleet Air Arm, led to a need for the Royal Air Force to take over the provision of Airborne Early Warning for the UK Air Defence Region. As an interim solution until a purpose built system could be procured, the radar and electronic systems from redundant Gannets were fitted to similarly redundant Avro Shackletons; the Shackleton was a maritime patrol aircraft then in the process of being replaced. However, this still meant that the Royal Navy, then in the process of introducing a new type of small aircraft carrier incapable of operating conventional fixed-wing aircraft, lacked an embedded AEW platform that could be used as part of the carrier task group. This lack of organic AEW capability following the withdrawal of the Gannet was seen as misguided, particularly following the experience of the Falklands War, in which the Royal Navy lost four ships due to the Task Force being reliant on shipborne air search. As a consequence, the Westland Sea King helicopter was modified to incorporate the Searchwater radar system for use in the AEW role from the Invincible class.
One of the proposals for an AEW platform in the Queen Elizabeth class was to use the V-22 Osprey tiltrotor aircraft, with a radome similar to that of the Sea King mounted on the tail ramp
The size of the Invincible class, combined with it only being capable of operating helicopters and V/STOL fixed-wing aircraft, limited the types of aircraft it could potentially carry in the AEW mission. Despite the limitations of the Sea King, in terms of its operating altitude and endurance, it remained the only feasible option from its introduction, in spite of efforts to design a platform more suitable - one such attempt came when BAe undertook a private study into the use of the proposed P.1216 advanced STOVL aircraft as an AEW platform, with a straight form wing and podded radar system. However, this proposal would have had a span of more than 60 ft, which was deemed the upper limit for operation aboard Ark Royal, and thus would have been difficult to accommodate on a ship the size of Invincible.
To coincide with the introduction of the new Queen Elizabeth-class, a new AEW system was sought - initially a number of proposals were raised, as it was unclear what type of ship the new carrier would be. Once it was confirmed that Queen Elizabeth would be a STOVL type ship, it was clear that ether a new helicopter based system, or a system based around a STOVL fixed-wing aircraft, such as the V-22 Osprey, would be required. It was eventually decided that a new, palletised system named "Crowsnest" would be operated from the Royal Navy's existing Merlin helicopters, to be operational by 2019. Shame that, would love to an Osprey in FAA colours...
The majority of Royal Navy Gannets were scrapped following withdrawal. The drawdown of the Gannet force in the late 1960s and early 1970s however led to a significant amount of electronic equipment being removed from the Gannet airframes for installation in Avro Shackleton aircraft of the Royal Air Force, which allowed the RAF to undertake its own AEW operations. In addition, a handful continued flying operations in the hands of civilian operators into the 1980s – one was used by Hamilton Standard in the United States for propeller vibration trials, while another was used by Dowty Rotol for propeller development purposes. In addition, a further AEW3 was used as a private display aircraft at airshows until the late 1980s. As of 2012, one aircraft (XL500 civil registered as G-KAEW), which was once flown by Prince Charles, was undergoing comprehensive restoration to airworthy condition by Hunter Flying.
Gannet AEW.3 XL472 at Gatwick Aviation Museum
Gannet AEW.3 XL450, is displayed at the Flugausstellung Hermeskeil in Germany
Five aircraft are on display:
Gannet AEW.3 XL472 at the Gatwick Aviation Museum, Surrey, England
Gannet AEW.3 XL497 at the Dumfries and Galloway Aviation Museum, Scotland
Gannet AEW.3 XL502 at Yorkshire Air Museum, England
Gannet AEW.3 XL503 at the Fleet Air Arm Museum, Yeovilton
Gannet AEW.3 XP226 at the Newark Air Museum, England
Gannet AEW.3 XL482 is displayed at the Pima Air Museum, Arizona
[/URL[URL=http://s820.photobucket.com/user/timhed ... c.jpg.html]
TTFN
