As usual the first section to be built is the cockpit. The ejection seat was the first to be tackled. The kit seat is six parts but the photo etch detail set has twenty five parts. After removing the kit levers and handles I replaced these with the photo etch replacements and painted the seat. I added the seatbelts and warning placards to finish off the ejection seat. The instrument panel was sanded down smooth and the photo etch sections were installed. I used clear gloss paint for the gauges and displays to replicate the glass faces. For the cockpit tub I sanded down the side panels and replaced them with the photo etch ones. The kit pedals were cut off and replaced with the photo etch versions. The control stick, instrument panel, and pedal assembly were installed completing the cockpit. I then prepared the inside of the fuselage for the cockpit area.
I still need to detail the nose wheel bay and the rest of the inside of the fuselage and engine area before I can close up the fuselage. I am hoping to have the fuselage closed up by the end of the week.
You can see all the photos and details from the start in the build log at: https://davidsscalemodels.com/build-log ... k-vma-214/
