This means you can add them to your profile signature, which will let everyone know what GBs & SiGs you've entered.
To get the SiG badge to show up in your signature you will need to copy and past the below line of code into your signature section on your profile, but you must remember to add
Please make sure that when you have two or more, to put all the separate codes on the same line and not under each other. This will save space and make it look a lot neater - Thanks
A massive THANK YOU to Richard for supplying all the ISM GB & SIG badges
Any problems just ask
