barryf1fan wrote: ↑Tue Feb 05, 2019 3:15 pm
More please!! Off to a great start. [Sub'd]
Twokidsnosleep wrote: ↑Tue Feb 05, 2019 3:07 pm
You are going to love this kit, it builds up extremely well
Luke looks good so far
Thanks guys! Today I made great headway. It wasn't without trials and tribulations but I am very happy with the progress.
Because I was unsure where to start I just started with step one, seemed logical. Right away I thought that I should leave the front of the motors off of the S Foils so I could paint the N1 blades; that's what I am calling them... N1 blades. Anyways if you look at this photo maybe you will notice the problem.
Untitled by
M M
I sent the S Foils to prime and found a great old can of Flat Aircraft Grey. I am going to have to pick up more of it because it's nice. Here is where I discovered my first problem.
Untitled by
M M
Oh well, I sent the offending piece to paint and started painting the N1 fan blades. It was a difficult job. Once that was finished I decided to mix up a custom color for the starship. Gloss white + light sky + a drop of flat black and a dash of Mr. Hobby Leveling Thinner. I think I had too much thinner because I did not like the way it was brushing on there. It was too light and patchy and I thought I am never going to make this look good.
Digging around my box of spray cans I found a flat white that would probably look good over the grey.
Untitled by
M M
I masked everything up and away I went. Well, my can of white was dead. Dee Eee Dee dead. Looking around the only thing I have left that was white was some surface primer. And HOLY COW I loved it! I laid it on pretty thin but I figure with the weathering I intend on doing it was a good thing.
Untitled by
M M
With that done it was time to do a little detail painting. This is my favorite part of any build. I take my time and really think about what I am trying to do.
I will go out and say this now but I think this genre of modeling is my favorite. I can paint it any color I want and if there is a blem, well guess what, this is an old starship! It supposes to have blemishes. Anyways I started on the burner section of the engines. I had seen some great examples of heat bluing at the LHS and asked the guy how he did it. He told me that he uses Tamiya Metalic blues to make it work. Well, I don't have any blue but I do have brown, gold, gun metal, chrome, and aluminum. Here is what I came up with.
Untitled by
M M
I touched them up a bit more before the end of the night and think they look great. From here I moved on to the engines within the S Foils. I know I want to dirty them up a bit but though they look *Meh* in flat grey. A coat of Gun Metal and I was loving the look!
Untitled by
M M
Here is a good example of the N1 Fan blades painted up. I just used a little flat white to touch up around the inlet. There will be a soot wash eventually.
Untitled by
M M
Just for grins, the rear of the burner can. If you notice by my thumb I was adding flat aluminum to different parts of the body. This thing looked like an actuator of some sort and looks good silver.
Untitled by
M M
Here is where the real fun began. This again is why I like the sci-fi genre. It's not exactly like the movie but who cares! It looks cool. This is the section behind the Astromech that gets covered but I thought it would be a good exercise in detail painting. I coated it with a few coats of Future and then added a little pin wash.
Untitled by
M M
I will say the photos show more detail then I can pick up with my eye but I didn't spend a lot of time going back over this part since it will be covered. Also I think this photo was before my wash.
Anyways here is the cockpit. This took some time but I love it.
Untitled by
M M
Before decals
Untitled by
M M
The yoke and the big red fire button!
Untitled by
M M
Glareshield before decals and further detail painting
Untitled by
M M
If you zoom in or go to Flickr you can see the side decals (pilots right in view)
Untitled by
M M
I am impressed with the Bandai decals. The right side of of the cockpit has decals that fold around. With some Micro Sol they folded fine. I also layered up the Micro Sol to get the raised detail behind to be pronounced a bit with the decals on them. You will never see it but its the thought that counts... right?
With that all finished I put a few coats of Future on the decals an on the areas I might want to try and add a little more Panel Line wash too.
Next up I plan on masking the cockpit and spraying the fuselage grey and white primer. I think all the red parts I will paint by hand red. I am trying to decide if I want to paint them grey, white, then red or just white and a coat of red. I dunno.
Thanks for following along!
-M
