Robocop bust
Fantasy, military, gundam etc
Johnrama83
Robocop bust
Post by Johnrama83 »
Hi everyone quick question for figure painters a friend of mine has 3d printed me a Robocop bust does anyone know the best colour to use to get the realistic look
Re: Robocop bust
Oh so many ways to do the metal finish. Really depends on what you have on hand.
A good primer is a must. Robos cop has a black middle so air would go Ultimate gloss black primer
Then the paint options: Alclad Aluminum, Mr Colour Silver, Tamiya silver or even AK True Metal paints…on and on
I did a resin printed Mandelorian and used the True Metal bright aluminum. You brush paint it in and then burnish it
BigWall
Re: Robocop bust
Post by BigWall »
Check out some of the figure painters that do non-metallic metal. It's a bit more difficult looking but it comes out very nicely. Squidmar Miniatures on YouTube is a good place to look
Joe
Johnrama83
Re: Robocop bust
I only use spray cans as don’t have air brush, I’ve been told to use filler primer on it, I have the Tamiya silver I used on my Peugeot rally car what looks similar to Robocop
MrBowcat
Re: Robocop bust
Post by MrBowcat »
Robocop has a bluish tinge to the metal.
Si vis pacem, para bellum
Re: Robocop bust
If you want to replicate the shine from the movie you need to sand down the metal surfaces first. They are far too rough and will not give you a metal look regardless of what paint you use.
As its resin, wear a mask and hoover your bench regularly.
Once the surface is smooth you need a gloss black primer specially for metallics then a metal coat such as from Alclad or Vallejo's metal color range.
As mentioned, get the surfaces smooth, that's the key. The rest is gravy :th:
Return to “Figures”
