I'm starting a new build of the quite new 1/72 scale Yak-130 kit from Zvezda.
This will be a buddy build together with ChancerNW, a gentleman that contacted me on YouTube. I will make vlogs on my YouTube channel, but I will also put up a regular build-thread as well
I did a YouTube inbox review of the kit a while ago, so I will not go into the details of the kit.
[youtube]n2FptPydmOA[/youtube]
But here's the box contents anyway:
The subject itself is a modern trainer and light attack aircraft produced by russian manufacturer Yakovlev. It's NATO codename is "Mitten"
So.... The build starts off with assembling the engines.
Kit parts look wornderful.
I will paint the airscoops before assembly. I'll use Gloss Black Primer andf ALclad Duraluminium for the metal parts and Ultimate White primer and Tamiya X-2 for the white air intakes.
Assembly of the parts for the main landing gear bays
A sneak-peek of the PE fret to make sure that there are no PE parts that should be included. But all parts seems to go into the cockpit
Assembly of the engines. Everything fits together perfectly, but the kit is quite engineered
Ok.... back to the landing gear bay.. Got some ejection pin marks to fix.
Dryfitting.... just to check that everything aligns up properly
Bottom plate with landing gear bay seprator (sidewall)
...and a small navlight
Here's the first episode of the buddy build video:
[youtube]ZRHSm3EHoLg[/youtube]
Stay tuned!
