So in between sorting out the photos from the air show I've managed to grab the odd half-hour at the bench to move this along...
First up some wings - I mean what's an X-Wing without Wings? Just an X I guess... anyway... everything was given a coat of Ultimate white primer, which was then masked off and sprayed with the Vallejo Model Air Deep Sky to produce the St Andrew's saltire section of the flag
This was then masked again and the exposed parts coated with Ultimate Gelb primer followed by a couple of coats of the Mode Air Red
I decided the vertical white component of the St George's cross was too broad so re-masked it to add a bit more red
I then lightly pushed the two wing sections together so I could see the effect in place and decided I was happy enough with this
Along with this I'd followed the same process with some of the other major parts (except for the blue)… all the masking has been done with a mix of Tamiya standard masking tape as well as various widths of Aizu tape from Ultimate
Since I wanted to pick out the panel lines the main components were given a coat of Alclad Aqua Gloss followed by a black clay wash, and then initial assembly happened
I've also loose fitted it to the base to help avoid any more scuffing...
There's a couple of places where I've had to touch up some of the paintwork due to scuffing and general ham-fistedness so that'll need re-glossing to bring it all in again
As you can see the engine cowlings, lasers & nose are all missing at this point as I'm still figuring out what white accents I want where - actually I think I've got the lasers sorting in my head so they'll probably be next
Also need to build a droid and work out which canopy to use. [mention]Twokidsnosleep[/mention] Scott when you built yours do you remember if you used the clear parts or glazed the plastic frame?
Thanks as always for looking - hope you like where this is going.
