AMK 1/48 IAI Kfir C7
Post your in progress builds threads here
Hey Guys!
I will enter this SiG building the IAI Kfir.
I will use the AMK 1/48 Kfir C2/C7 kit also adding some aftermarket, where I will build the C7 version of the aircraft
Boxart:
ImageIMG_20170701_085608 by Tommy Killander, on Flickr
Assembly Instructions and aftermarket (Eduard Zoom kit, masking set and Master pitot-tube + Angle of Attack probe):
ImageIMG_20170701_085454 by Tommy Killander, on Flickr
Sprues:
ImageIMG_20170701_090201 by Tommy Killander, on Flickr
ImageIMG_20170701_090345 by Tommy Killander, on Flickr
ImageIMG_20170701_090841 by Tommy Killander, on Flickr
ImageIMG_20170701_090603 by Tommy Killander, on Flickr
Decals and clear parts:
ImageIMG_20170701_085902 by Tommy Killander, on Flickr
Background:
The Israel Aircraft Industries Kfir (Hebrew: כְּפִיר‎, "Lion Cub") is an Israeli-built all-weather, multirole combat aircraft based on a modified French Dassault Mirage 5 airframe, with Israeli avionics and an Israeli-built version of the General Electric J79 turbojet engine.
The project that would ultimately give birth to the Kfir can be traced back to Israel's need for adapting the Dassault Mirage IIIC to the specific requirements of the Israeli Air Force (IAF).
The all-weather, delta-winged Mirage IIICJ was the first Mach 2 aircraft acquired by Israel from then close ally France, and constituted the backbone of the IAF during most of the 1960s, until the arrival of the Douglas A-4 Skyhawk and, most importantly, the McDonnell Douglas F-4 Phantom II, by the end of the decade. While the Mirage IIICJ proved to be extremely effective in the air-superiority role, its relatively short range of action imposed some limitations on its usefulness as a ground-attack aircraft.
Thus, in the mid-1960s, at the request of Israel, Dassault Aviation began developing the Mirage 5, a fair-weather, ground-attack version of the Mirage III. Following the suggestions made by the Israelis, advanced avionics located behind the cockpit were removed, allowing the aircraft to increase its fuel-carrying capacity while reducing maintenance costs.
By 1968, Dassault had finished production of the 50 Mirage 5Js paid for by Israel, but an arms embargo imposed upon Israel by the French government in 1967 prevented deliveries from taking place. The Israelis replied by producing an unlicensed copy of the Mirage 5, the Nesher, with technical specifications for both the airframe and the engine obtained by Israeli spies. Some sources claim Israel received 50 Mirage 5s in crates from French Air Force (AdA), while the AdA took over the 50 aircraft originally intended for Israel.
Operational History:
The Kfir entered service with the IAF in 1975, the first units being assigned to the 101st "First Fighter" Squadron. Over the following years, several other squadrons were also equipped with the new aircraft. The role of the Kfir as the IAF's primary air superiority asset was short-lived, as the first F-15 Eagle fighters from the United States were delivered to Israel in 1976.
The Kfir's first recorded combat action took place on November 9, 1977, during an Israeli air strike on a training camp at Tel Azia, in Lebanon. The only air victory claimed by a Kfir during its service with the IAF occurred on June 27, 1979 when a Kfir C.2 shot down a Syrian MiG-21.
By the time of the Israeli invasion of southern Lebanon in 1982 (Operation Peace for Galilee) the IAF was able to use both its F-15s and F-16s for air superiority roles, leaving the Kfirs to carry out unescorted strike missions. Shortly afterwards, all IAF C.2s began to be upgraded to the C.7 version, with enhanced weight performance, making the Kfir more suitable to its new fighter-bomber role. During the second half of the 1990s, the Kfirs were withdrawn from active duty in the IAF, after almost twenty years of continuous service.
Specifications:
General characteristics
  • Crew: 1
  • Length: 15.65 m (51 ft 4¼ in)
  • Wingspan: 8.22 m (26 ft 11½ in)
  • Height: 4.55 m (14 ft 11¼ in)
  • Wing area: 34.8 m² (374.6 sq ft)
  • Empty weight: 7,285 kg (16,060 lb)
  • Loaded weight: 11,603 kg (25,580 lb) two 500 L drop tanks, two AAMs
  • Max. takeoff weight: 16,200 kg (35,715 lb)
  • Powerplant: 1 × IAl Bedek-built General Electric J-79-J1E turbojet
    • Dry thrust: 52.9 kN (11,890 lb st)
    • Thrust with afterburner: 79.62 kN (17,900 lb st)
Performance
  • Maximum speed: 2,440 km/h (2 Mach, 1,317 knots, 1,516 mph) above 11,000 m (36,000 ft)
  • Combat radius: 768 km (415 nmi, 477 mi) (ground attack, hi-lo-hi profile, seven 500 lb bombs, two AAMs, two 1,300 L drop tanks)
  • Service ceiling: 17,680 m (58,000 ft)
  • Rate of climb: 233 m/s (45,950 ft/min)
Armament
  • Guns: 2× Rafael-built 30 mm (1.18 in) DEFA 553 cannons, 140 rounds/gun
  • Rockets: assortment of unguided air-to-ground rockets including the Matra JL-100 drop tank/rocket pack, each with 19× SNEB 68 mm rockets and 66 US gallons (250 liters) of fuel
  • Missiles: 2× AIM-9 Sidewinders or Shafrir or Python-series AAMs; 2× Shrike ARMs; 2× AGM-65 Maverick ASMs
  • Bombs: 5,775 kg (12,730 lb) of payload on nine external hardpoints, including bombs such as the Mark 80 series, Paveway series of LGBs, Griffin LGBs, SMKBs,[35] TAL-1 OR TAL-2 CBUs, BLU-107 Matra Durandal, reconnaissance pods or Drop tanks
Cheers!
Re: AMK 1/48 IAI Kfir C7
Hi Tommy I thought you might drop in, it was looking like Paul was going to be the only aircraft entered, good luck with your build :th:
privatepete wrote: Sat Jul 01, 2017 9:05 am Hi Tommy I thought you might drop in, it was looking like Paul was going to be the only aircraft entered, good luck with your build :th:
Thanks, Pete! :)
This will be fun, I'm looking forward to the three colour scheme and the kit itself looks awesome :thumb2:
papatika
Hungary
Post by papatika »
Hi Tommy!
Never heard of this manufacturer. :roll: :oops:
Anyways, looking forward to see your progress! :)
Attila
Nice choice there mate
demarcation
Post by demarcation »
I'm sure it will be a jaw dropper Tommy, looking forward to your build!
//Anders
snowman819
Post by snowman819 »
I'm going to follow this Kfir.
Between the F16s and the Kfir, I'm spoilt for choices on which israeli jet to build.
:scratch::
Modelling for health and happiness.:D
Hey guys,
I'm away from the bench until Monday but I plan to start the build when back. Really looking forward to get started :)
Wohoo! Back at the bench :banana:
Just came back after a camping tour with the family - 4 days at the beach living in a rented mobile home. I little tired after the driving, but I got some bench work today when I got home.
Finally started with this build - I just wanted to finish my Shinden first.
This is my first experience of an AMK kit and I'm very impressed with it. Details looks really good. Very crisp details and the quality of the styrene is top notch :thumb2:
ImageIMG_20170716_181307 by Tommy Killander, on Flickr
There are, however, som ejection pin marks at the bottom of the cockpit tub, so I'm using a scalpel to scrape off the "circle marks".
ImageIMG_20170716_190354 by Tommy Killander, on Flickr
I have removed the buttons and dials of the IPs to prepare them for the PE panels.
ImageIMG_20170716_200844 by Tommy Killander, on Flickr
Hey Guys!
Got some more done today with painting and assembly of the wheel bays.
The wheel bays should be white and after some thinking I decided to paint the different parts before assembly, since I'm a bit concerned of how to get a good coverage of the white. Painting into corners is difficult - it's tricky to avoid dusting (bounce-back); buildup of dry paint that bounces around or flooding caused by too much paint.
But painting the parts separately before assembly will make the build more difficult since the parts needs to be glued from the backside, to avoid destroyed paintjob. :think:
Lets start with White and Grey Primer
ImageIMG_20170717_122718 by Tommy Killander, on Flickr
base coat of XF-19 Sky Grey (with some XF-2 White). Wheelbays painted with XF-2 White.
ImageIMG_20170717_205114 by Tommy Killander, on Flickr
Inside of engine cover painted with Vallejo Metal Steel
ImageIMG_20170717_210528 by Tommy Killander, on Flickr
Assembly of the wheel wells.... A bit tricky to get everything aligned correctly :crazy:
ImageIMG_20170717_213535 by Tommy Killander, on Flickr
What the f..... :wtf: :shock:
ImageIMG_20170717_221523 by Tommy Killander, on Flickr
It's supposed to look like this. The fuselage sides will fill that gap. Other kits by AMK are know for their great fit; I hope this kit holds up to that expectation... :shifty:
Speaking of fuselage halves - look how nicely AMK have placed the injection-ports! The upper seam is free from ports so there should be a minimum of sanding. :thumb2:
ImageIMG_20170717_101625 by Tommy Killander, on Flickr
Hey Guys!
I have started to work on the cockpit today !
Here's a photo of a mockup of the cockpit, it's the best I have found so that will have to do... :shifty:
There's some really nice PE for the IPs and some details on the sidewalls.
ImageIMG_20170718_173429 by Tommy Killander, on Flickr
There also some panels and control-boxes for the compartment behind the ejection seat.
ImageIMG_20170718_181350 by Tommy Killander, on Flickr
ImageIMG_20170718_204232 by Tommy Killander, on Flickr
IP cover painted with XF-1 Black and drybrushed with XF-54 Dark Sea Grey
ImageIMG_20170718_204323 by Tommy Killander, on Flickr
I drybrushed the edge of the HUD glass with X-26 Clear Green to give the glass some contrast so it will be seen through the windscreen.
ImageIMG_20170718_212546 by Tommy Killander, on Flickr
Stay tuned!
Awesome work there mate the instruments and panel look great :th:
gaz45 wrote: Wed Jul 19, 2017 12:17 pm Awesome work there mate the instruments and panel look great :th:
Thanks gaz45 :)
Today I have done some weathering of the cockpit using a dark grey mix of 502 Abteilung Black and Dust... My goal was to find a colour tone that works both with the black IP cover and the Light grey interior - so I had to experiment a bit...
ImageIMG_20170719_222121 by Tommy Killander, on Flickr
ImageIMG_20170719_222250 by Tommy Killander, on Flickr
ImageIMG_20170719_222305 by Tommy Killander, on Flickr
I will leave that to dry until tomorrow. I will then give it a cover of flat varnish.
So I contined with the main wing section. Some holes needs to be drilled for the C7 version and for the hardpoints (droptanks and missiles). This baby will have a full loadout :pistols:
ImageIMG_20170719_224237 by Tommy Killander, on Flickr
ImageIMG_20170719_231113 by Tommy Killander, on Flickr
There are two lenses for the navigation lights at each wingtip. I glued them with a very small amount of Tamiya Extra Thin.
ImageIMG_20170719_231857 by Tommy Killander, on Flickr
The lenses should be tinted with Clear Red and Clear Blue (!)
ImageIMG_20170719_232506 by Tommy Killander, on Flickr
I use my standard trick to put kitchenfoil behind the lens as a reflector. I just press it into the paint.
ImageIMG_20170719_233524 by Tommy Killander, on Flickr
This is the result, I'm happy with that :)
ImageIMG_20170719_233555 by Tommy Killander, on Flickr
Hey guys!
I have flatcoated the cockpit details now and added some pigments to the bottom of the cockpit tub
ImageIMG_20170720_153636 by Tommy Killander, on Flickr
And with that done I'm ready to assemble the cockpit and put the fuselage halves together
ImageIMG_20170720_154939 by Tommy Killander, on Flickr
ImageIMG_20170720_155109 by Tommy Killander, on Flickr
There are many different approches to doing this and since I'm a big fan of gluing stuff from the inside and this kit design is quite open, I will do just that.
ImageIMG_20170720_162421 by Tommy Killander, on Flickr
...and while the glue is curing I'm enjoying a classic Swedish coffee-break ("fika") with cinnamon rolls :cheers2:
ImageIMG_20170720_160536 by Tommy Killander, on Flickr
So with that taken care of and my hands washed from all sugar, butter and cinnamon, let's move on to the main wing section.
ImageIMG_20170720_165720 by Tommy Killander, on Flickr
There are a couple of ejection pin marks on the air intakes that needs some attention.
ImageIMG_20170720_173937 by Tommy Killander, on Flickr
In an earlier post in this thread I mentioned that the fuselage walls will fill the gaps in the main wheelbays.
ImageIMG_20170720_201145 by Tommy Killander, on Flickr
...that is not completely true; there's still a small gap on tke left side
ImageIMG_20170720_201155 by Tommy Killander, on Flickr
It has to be closed with a small strip of styrene near the wingroot. AMK engineering department have really gone wild with this kit :crazy: :D
ImageIMG_20170720_201303 by Tommy Killander, on Flickr
So let's prepare some more stuff for white Ultimate primer
ImageIMG_20170720_203126 by Tommy Killander, on Flickr
Part from the wheelbays, the Python-3 AAMs and the inside of the air intakes will be white...
ImageIMG_20170720_205912 by Tommy Killander, on Flickr
JonMW
Post by JonMW »
Great progress! AMK seems ta have a pretty strange way of assembly, but if it works I guess it's good.
It's always good with some fika!
JonMW wrote: Thu Jul 20, 2017 9:38 pm Great progress! AMK seems ta have a pretty strange way of assembly, but if it works I guess it's good.
Thanks Jon ! :)
Let's hope that AMK lives up to it's reputation in terms of accuracy and fit.
Yeah, fika is always good!
Back to the bench again.... :)
I have continued to work on the Martin Baker Mk 10 ejection-seat.
I looks quite familiar and I found out that it's been installed in more than 30 different aircrafts, including Tornado, F/A-18 Hornet and JAS 39 Gripen.
So, the kit contains plastic parts for two differrent bang-seat, but I'm going to use the Mk. IN10LH for the Kfir C7.
ImageIMG_20170721_002104 by Tommy Killander, on Flickr
The frame for the ejection seat is two parts with a joint that goes in the centre. The seat cushion covers some of the seam but it is visible at the headrest. I made an attempt to use PPP as a filler.
ImageIMG_20170721_004246 by Tommy Killander, on Flickr
...but I could not get it to set properly in the headrest seam, it worked fine for the top and lower though. So I used CA-glue instead, since it has some self-leveling properties.
ImageIMG_20170721_005246 by Tommy Killander, on Flickr
The details of the plastic parts are very good - it's not far behind a resin counterpart
ImageIMG_20170721_011756 by Tommy Killander, on Flickr
Ok... back to the sprayboot for a while... I have painted the white parts with XF-2 White, primed the backseat with Ultimate black primer and sprayed on XF-1 Black for the ejection seat frame and XF-51 Kahki Drab for the seat cushion.
ImageIMG_20170721_114822 by Tommy Killander, on Flickr
Drybrushing of the frame
ImageIMG_20170721_120210 by Tommy Killander, on Flickr
ImageIMG_20170721_120143 by Tommy Killander, on Flickr
The seat cushion where "chipped" with XF-49 Kahki and XF-60 Dark Yellow
ImageIMG_20170721_120911 by Tommy Killander, on Flickr
ImageIMG_20170721_120929 by Tommy Killander, on Flickr
I painted the sides of the yellow seat PE parts using XF-4 Yellow Green
ImageIMG_20170721_124027 by Tommy Killander, on Flickr
Using a glassfibre pen to make the back of the PE parts more rugged so they stick better to the CA-glue. It's a good idea to do this while they are still on the fret ;)
ImageIMG_20170721_124818 by Tommy Killander, on Flickr
After a couple of hours all the PE where placed and everything was glosscoated with Aqua Gloss
ImageIMG_20170721_141830 by Tommy Killander, on Flickr
Dryfitting...
ImageIMG_20170721_142025 by Tommy Killander, on Flickr
ImageIMG_20170721_142150 by Tommy Killander, on Flickr
I will give it a wash with Abt502 Dust, flat coat it and put is away for now, since this will be one of the last things that go in at final assembly.
Hi there!
I've spent some time on the air scoops today as well...
I would like to have white air intakes, so I have prepared and prepainted all the parts that was needed - or so I thought.... :shock:
After some dryfitting to see how I should mask the intakes I realised that I needed to paint the inside of the front wingsection as well :scratch::
ImageIMG_20170721_152104 by Tommy Killander, on Flickr
But before I could do that I needed to deal with a couple of strange marks on the inside, that looked like marks for drilling or something like that. There where also a couple of pin ejection marks.
So Liquid Sprue my old friend, here we go again.... :violin:
ImageIMG_20170721_152511 by Tommy Killander, on Flickr
This needs to cure for a couple of days before I can sand it down and put on the white paint. But I have prepared the masking already...
ImageIMG_20170721_154806 by Tommy Killander, on Flickr
I will continue building some other parts - there are still lots of things to do, so this not a blocker for me :D
Last edited by TommyKillander on Sat Jul 22, 2017 11:27 pm, edited 1 time in total.
Some fine detailing going on here :th:
Kevthemodeller wrote: Sat Jul 22, 2017 7:03 am Some fine detailing going on here :th:
Thanks Kev! :)
papatika
Hungary
Post by papatika »
Wow Tommy!
The cockpit looks brilliant! :bow:: Keep up the good work!
papatika wrote: Sat Jul 22, 2017 7:03 pm Wow Tommy!
Thanks papatika!
Today I have continued the build by gluing random stuff together, starting with the GBU-12s and fuel tanks
The "exhaust" (well it's not rocket propelled) of the GBU-12s look a bit ugly
ImageIMG_20170722_124745 by Tommy Killander, on Flickr
So I will fix that with a small disc of plasticard
ImageIMG_20170722_124907 by Tommy Killander, on Flickr
Assembly of the external fuel stores
ImageIMG_20170722_131114 by Tommy Killander, on Flickr
ImageIMG_20170722_174230 by Tommy Killander, on Flickr
I will leave them overnight so the glue fully cures, before I start sanding and polishing them.
Hackovsky
Czech Republic
Post by Hackovsky »
Incredible job done! And I can see finally the AMK. I was thinking of buying the Kfir from them. But it seems like nice kit overall.
Hackovsky wrote: Sat Jul 22, 2017 9:13 pm Incredible job done! And I can see finally the AMK. I was thinking of buying the Kfir from them. But it seems like nice kit overall.
Thanks Hackovsky :)
demarcation
Superb work on that cockpit, looks brilliant! :thumb1: :bow::
//Anders
Truly stunning work Tommy, that cockpit :jd: I've know idea how you do this kind of work well I do it called skill :clap: , keep up the excellent work :th:
Nice mate :thumb2:
demarcation wrote: Sun Jul 23, 2017 12:12 pm Superb work on that cockpit, looks brilliant! :thumb1: :bow::
Thank you very much, Anders! :)
privatepete wrote: Sun Jul 23, 2017 1:50 pm Truly stunning work Tommy, that cockpit :jd: I've know idea how you do this kind of work well I do it called skill :clap: , keep up the excellent work :th:
Thanks Pete, for those kind words :bow::
Nev wrote: Sun Jul 23, 2017 1:54 pm Nice mate :thumb2:
Thank you, Nev :thumb2:
Okey, the wing section has rested for a couple of days now so I decided to sand down the "sprue glue" and paint it white.
ImageIMG_20170723_120938 by Tommy Killander, on Flickr
I found a couple of rails for the Python-3 missiles that should be white, so I primed and painted them in XF-2 White too :whistle:
ImageIMG_20170723_124602 by Tommy Killander, on Flickr
Fuselage and wing section where assembled after that. Nothing remarkable, the fit was good. There are a couple of small seams on the underside that I need to take care of.
I got cold feet with all that masking tape around the airscoops, so I decided to cut some of it off - there is no way that I could remove all tape strips after assembly. Now I have a reasonable chance to reach them with a tweezer. I will stuff foam into the air intakes before I start painting to protect the white inside.
ImageIMG_20170723_200844 by Tommy Killander, on Flickr
I have attached the small strips at the wingroot and this is what the main wheelbays looks like now.
ImageIMG_20170723_200859 by Tommy Killander, on Flickr
Canards fitted :dance:
ImageIMG_20170723_210216 by Tommy Killander, on Flickr
Vents - nice details.
ImageIMG_20170723_213023 by Tommy Killander, on Flickr
There is still a lot of sub-modules to build, so stay tuned ! :th:
Hey Guys!
I have continued with the droptanks and some random stuff today.
The droptanks where glued together yesterday and the seams where covered with CA-glue as a filler.
Today I sanded down the excess glue and material and buffed them with an Ultimate buffing stick.
ImageIMG_20170724_143908 by Tommy Killander, on Flickr
It took a while to do that and I had to replace the buffing stick - the one at the top have been used on three models it deserved to be dismissed :D
ImageIMG_20170724_150254 by Tommy Killander, on Flickr
The buffing stick is one of my most used tools, I basically use it on every part of a kit when I'm building.
Finished for now - I need to rescribe some lost panels, but after that they are ready for primer.
ImageIMG_20170724_154524 by Tommy Killander, on Flickr
Some noseweight is always good. The Instructions doesn't mention any noseweight, but I'm not taking any chances....
ImageIMG_20170724_182352 by Tommy Killander, on Flickr
I'm a but surprised about the bad fit of the Pave Penny (laser designator pod) to the fuselage :scratch:: I need to check some pictures to see if it should actually look like that before I fix it... :geek:
ImageIMG_20170724_201909 by Tommy Killander, on Flickr
Cheers!
Hi there!
It's been a frustrating day today, bumped into my first real problem - all caused by myself ofcourse.... :roll:
I glued the nosecone together after I carved out a rectangular hole for a vent port that is used on the C7. All parts separated from the sprues and cleaned up preparing for the assembly. So far so good....
ImageIMG_20170725_155302 by Tommy Killander, on Flickr
Built together some parts to the rear of the aircrafts, I guess these are part of the countermeasure system on the aircraft.
ImageIMG_20170725_155320 by Tommy Killander, on Flickr
So... after a while it was time to glue in vent port (part D3 in the assembly instructions). And guess what - I could not find it anywhere :?
ImageIMG_20170725_180523 by Tommy Killander, on Flickr
After checking the bench, floor, the small boxes where I normally put small parts and finally even the trashcan I still could not find it. After one hour I gave up. My workarea is in the basement of my house where I have an old concrete floor. If something small/delicate hits the floor that is normally a sure "write-off"" for that part.
Anyway, I started to scratch build a substitute using a small piece of the injection port from a sprue-tree. After approx 1 hour of work I had something that looked fairly OK and would possibly pass for a vent port. I just needed to polish the part, and when I did that it went PING! across the room into the darked and dirtiest area of the basement :eeek: :bash:
So, while thinking about how to solve this I will continue with other parts of the build. I might have to order a replacement part or scratch-building :doh: :violin:
- "...but not today", to recite Aragorn :D
Hey Guys!
I DID IT AGAIN :crazy: :bash: :bash: :wall: :wall: :wall:
I lost another small part!
I was a part that belonged to an air scoop on the bottom side.
This is seriously disturbing... maybe I should get a new hobby and do something else :think:
Okey. I have plenty of work to do so let's get started with some scratchbuilding fun :)
The part that is missing is the lower half of the airscoop, it has a plate at the bottom that protrudes a couple 1/10 mm. I dont have any plasticard with a suitable thickness, so I will have to use some PET-plastic instead.
ImageIMG_20170726_113240 by Tommy Killander, on Flickr
Glued with CA-glue since TET won't work
ImageIMG_20170726_113841 by Tommy Killander, on Flickr
ImageIMG_20170726_114956 by Tommy Killander, on Flickr
ImageIMG_20170726_115205 by Tommy Killander, on Flickr
The finished result - it's not perfect but good enough :shifty:
ImageIMG_20170726_121542 by Tommy Killander, on Flickr
I will attach the hardpoints on the underside, since everything will be painted in Gunze H308
ImageIMG_20170726_122132 by Tommy Killander, on Flickr
ImageIMG_20170726_133945 by Tommy Killander, on Flickr
ImageIMG_20170726_135801 by Tommy Killander, on Flickr
I also scratchbuilt the vent port for the nose-cone a second time, using a piece of a injection port from the sprue. It went quicker this time but I didn't get the shape as good as the first one.
ImageIMG_20170726_160226 by Tommy Killander, on Flickr
ImageIMG_20170726_161929 by Tommy Killander, on Flickr
I knocked off an antenna on the nose-cone, so I had to replace that too.... :ooops: :roll:
ImageIMG_20170726_163435 by Tommy Killander, on Flickr
ImageIMG_20170726_163743 by Tommy Killander, on Flickr
Can I please continue this build now without making a mess of everything !? :D
Awwrajt... Todays update!
Did some work yesterday on the hangout (really nice chatting with you guys) :)
Drilled a 0.9mm hole in the side of the fuselage to fit the angle-of-attach probe.
ImageIMG_20170727_113812 by Tommy Killander, on Flickr
I dryfitted the nose-cone and took the opportunity to attach the pitot tube as well. I find it easier to align it when I can use the full length of the aircraft as a reference.
ImageIMG_20170727_114244 by Tommy Killander, on Flickr
ImageIMG_20170727_115729 by Tommy Killander, on Flickr
The windshield has some instruments mounted at the top, so I had to scratchbuild a small box.
ImageIMG_20170727_120107 by Tommy Killander, on Flickr
ImageIMG_20170727_121921 by Tommy Killander, on Flickr
The result
ImageIMG_20170727_122204 by Tommy Killander, on Flickr
Windshield glued in place
ImageIMG_20170727_125026 by Tommy Killander, on Flickr
The AoA-probe is sharp like a needle, so I placed some hard foam and kabuki tape over it as a protection :tongue:
ImageIMG_20170727_130136 by Tommy Killander, on Flickr
Getting my nose in here to watch the show unfold
Wonderful modelling as usual from you Tommy
My highlights..the red and green lights, the awesome cockpit and the Gulf mug :thumb2:
Cheers bud, great thread so far
Twokidsnosleep wrote: Thu Jul 27, 2017 4:22 pm Getting my nose in here to watch the show unfold
Thanks buddy! :)
The build is going well, part from the lost parts. But I got that sorted out I think.
My 4 weeks vacation is coming to an end soon, so I need to get some other stuff done before I get back to work again. The build will slow down a bit I guess from now on, but there are plenty of time left in this SiG.
Hello fellas!
The windshield had a small step down to the front so I had to take care of that
ImageIMG_20170729_122458 by Tommy Killander, on Flickr
The step was sanded down and the surface of the windscreen was recovered using Ultimate buffing stick and some Tamiya Polishing compound
ImageIMG_20170729_124512 by Tommy Killander, on Flickr
Nose-cone mounted - it sure starts to look like an aircraft now :P
ImageIMG_20170729_134142 by Tommy Killander, on Flickr
Cockpit masked
ImageIMG_20170729_141300 by Tommy Killander, on Flickr
Air-scoops masked with some foam
ImageIMG_20170729_141325 by Tommy Killander, on Flickr
Wheelbays masked - Yeah, Tamiya Masking Tape Department wins :roll:
ImageIMG_20170729_184136 by Tommy Killander, on Flickr
And it's time for primer
ImageIMG_20170729_191252 by Tommy Killander, on Flickr
Primed with Utimate Products Grey primer
ImageIMG_20170729_205538 by Tommy Killander, on Flickr
A big step forward today.... I checked my paintrack and it seems that I'm a bit low on Gunze Aqueous paints :eeek:
I need to get H310 and the H308 jar is almost empty - so I have to order those ASAP
So I will continue building the remaining parts, mostly undercarriage and I will paint and weather other stuff in the meantime, so I will not sit on my hands until postie arrives :)
Stay tuned!
Fridgy
Post by Fridgy »
Awesome build as always Tommy :cheers2:
Mick
WIP: 1/12 Bandai BB-8 & R2-D2
Fridgy wrote: Sun Jul 30, 2017 9:56 am Awesome build as always Tommy :cheers2:
Thanks Mick for the kind words :)
demarcation
Awesome work as usual Tommy. Can't wait to see it with the camo on, you gotta love the IAF paint schemes! :banana:
//Anders
demarcation wrote: Sun Jul 30, 2017 6:09 pm Awesome work as usual Tommy. Can't wait to see it with the camo on, you gotta love the IAF paint schemes! :banana:
Thanks Anders :)
Yes, the colours are great - I love the painmt scheme on the C7 version, let's hope that I can get it right.
What can i say awesome work on the detail there mate :jd:
gaz45 wrote: Mon Jul 31, 2017 12:11 pm What can i say awesome work on the detail there mate :jd:
Thanks gaz45!
I have started to paint some weapons, first is the GBU-12 Laser Guided Bomb.
There is a decal for the yellow band, but I decided to paint it instead. I use pink as a base for yellow (my standard procedure)
ImageIMG_20170730_081534 by Tommy Killander, on Flickr
Cutting some masking tape
ImageIMG_20170730_094513 by Tommy Killander, on Flickr
Painted with XF-62 Olive Drab
ImageIMG_20170730_103605 by Tommy Killander, on Flickr
Python-3 IR homing AAMs. The body of the missile is painted with a light blue, but after checking some photos I thought that the standard XF-23 Light Blue seemed too dark - so I added XF-2 White in a mix of 1:1 ratio.
ImageIMG_20170730_133256 by Tommy Killander, on Flickr
Masking of the rollerons
ImageIMG_20170730_140119 by Tommy Killander, on Flickr
ImageIMG_20170730_142502 by Tommy Killander, on Flickr
Ready for gloss coat and decals (I'm not going to paint the bands) :D
Next up is the main landing gear. I'm a bit suspicious about this design.... :think: I don't understand why its done like that and I can't see any benefit from it.... Furthermore, the Eduard Masking kit does not have any roundel for the wheelhubs :wtf:
ImageIMG_20170730_160513 by Tommy Killander, on Flickr
My gut-feeling was right :crazy:
ImageIMG_20170730_161106 by Tommy Killander, on Flickr
:roll:
ImageIMG_20170730_163059 by Tommy Killander, on Flickr
The oleo struts look fantastic
ImageIMG_20170730_215957 by Tommy Killander, on Flickr
Nosewheel - it's possible to snap the wheel in place after the fork has been assembled. I have not decided if I should paint the wheel separately or not. Maybe I'll do that...
ImageIMG_20170731_212347 by Tommy Killander, on Flickr
Hey Guys!
Build goes a little slow now, since I got some other stuff going on at the same time. I'm building a new spraybooth :banana:
The sprue glue have cured enough now, so I have sanded down the excess material:
ImageIMG_20170802_200907 by Tommy Killander, on Flickr
The remaining small parts have been prepared for painting
ImageIMG_20170802_202003 by Tommy Killander, on Flickr
Primed with Ultimate Grey Primer, I also primed up a couple of spoons for paint tests
ImageIMG_20170802_203553 by Tommy Killander, on Flickr
I'm still waiting for the missing paints so I will continue with the ordnance.
Stay tuned!
Great work so far!
I like the spoons idea, I might do that in future!
ElCapitan wrote: Thu Aug 03, 2017 9:15 am Great work so far!
Thanks Rob :)
Yeah, it's a low risk way of testing out paint mixes and postshading - I always do that when I use a new paint for the first time, since I can even glosscoat and experiment with weathering before I make up my mind about what to do on the model.
Looks like the dogs *&^%$£"*. :th: :th: :th:
pourquoi61 wrote: Thu Aug 10, 2017 9:24 pm Looks like the dogs *&^%$£"*. :th: :th: :th:
Yes, but there are lot's of ¤%"&/¤&%" left to do ;)
Okay.... I'm back from a recent upgrade/renovation of my workarea (new spraybooth and lots of more storage), so I'm eager to complete this build now.
While I'm pondering over the approach for painting the cammo I decided to do some other stuff...
I find that it's really difficult to brushpaint the optics of a missile, so I'm just dipping the tip into the paint.
I leave the missiles "hang-drying" for a couple of minutes so to the paint sets
Added the rails
I will just glosscoat them and put them aside for now, so they are ready when it's time for weathering.
Hey Guys,
It's time for some test-shots of the cammo paint :banana:
The three tone top cammo consists of four paints, where the Light Gray Green is mixed from two of them (more on that below).
I had four spoons prepared with primer already, so here we go:
Bottom side painted with H308 FS36375, I might fade this paint a bit using a couple of drops of XF-2.
Next is the top side cammo;
The H313 YELLOW/SAND FS33531. Faded with highly diluted XF-55.
The H310 BROWN/DARK TAN FS30219. Faded by adding XF-55 (1:1 mix).
The FS34424 Light Gray Green is mixed from H312 and H314, where paint callout suggests a ratio of 6:4, but that ended up too green, so I mixed it 4:6 instead. The fading have been done using highly diluted H314.
This is the result:
All paint-mixes have been put in jars so I don't need to mix paints later on.
demarcation
Looking forward to see the your colors on the aircraft. Nice work!
//Anders
demarcation wrote: Thu Aug 31, 2017 9:06 pm Looking forward to see the your colors on the aircraft. Nice work!
Thanks Anders :)
I hope to be able to get some work done this weekend.
NorthernModeller
Post by NorthernModeller »
Loving the look of this. I like the results of the test pieces, they do look a good match :)
Return to “Build Threads”
