Millennium Falcon 1:72 Bandai PG. Handmade interior, custom lights and sound
If it doesn't exist..........yet
JoaquinGM
Spain
Post by JoaquinGM »
I am making the Millennium Falcon 1:72 Bandai PG with handmade interior, custom lights and sound
I plan to make custom interior.
I am using this as blueprints
The floor
SMAddict66
Re: Millennium Falcon 1:72 Bandai PG. Handmade interior, custom lights and sound
Post by SMAddict66 »
Ooooo am I looking forward to watching this :banana: :pop: .
Good luck with the build :cheers2:
Phil
On the bench - Trumpeter 1/32 Fairey Swordfish
Just off the bench - Airfix 1/48 Buccaneer S2B
Next on the bench - Airfix 1/48 EE Lightning F2A/F6
How cool is this awesome new ISM member?!!!...I will follow along as well
That's a great idea - really looking forward to seeing how you progress with this. :pop:
Very cool. I have one of these in the stash. Can you provide the files you used for the layout?
JoaquinGM
Spain
Post by JoaquinGM »
bfrd wrote: Mon Oct 08, 2018 3:08 pm Very cool. I have one of these in the stash. Can you provide the files you used for the layout?
This plans https://i.pinimg.com/originals/11/70/a6 ... c37a7f.jpg
I've been looking for a long time and these are the best blueprints that I've found.
JoaquinGM wrote: Mon Oct 08, 2018 3:48 pm
Thanks!
JoaquinGM
Spain
Post by JoaquinGM »
Twokidsnosleep wrote: Sun Oct 07, 2018 8:27 pm How cool is this awesome new ISM member?!!!...I will follow along as well
hehe, not cool, just want to try new things.
First I tried to make the corridors, it is very difficult because it is a toroid.
I tried styrene to make the corridors but I could not fold it properly.
Then I changed to extruded polystyrene to sculpt the corridors.
Knife and Dremel.
What are you considering for lights?
You can get some very small “smd” surface mount diodes that are tiny and pump out lots of light in different colours
I am sure you are a wiz with electronics already, I am just starting into them
JoaquinGM
Spain
Post by JoaquinGM »
Twokidsnosleep wrote: Mon Oct 08, 2018 9:01 pm What are you considering for lights?
I plan to use fiber optics and RGB leds controlled by a Arduino. I think that it's more power efficient and more easy to manage that individual leds.
Here is a youtube tutorial about fiber optics.
Timplastic
UN
Post by Timplastic »
This will be amazing too see come together
I like to know what you think even if it is critique , If you spotted it let me know
Trying to finish what I started, and take part
My youtube channel that needs some updates
https://www.youtube.com/channel/UCjQvLz ... subscriberImage
That is going to be a epic build!
Looking forward to this!
JoaquinGM
Spain
Post by JoaquinGM »
The main walls done.
Check that I can close the model
Firts tests with RGB Leds
For the engine I plan to use a RGB strip. WS2812 strip 5050rgb chip
I can change the colors of RGB Leds from blue to white
From Blue
to White
Individual RGB leds also works.
The individual leds are identical to the strip ones.
These individual leds are for the fiber optics.
JoaquinGM
Spain
Post by JoaquinGM »
Some corridor paint.
Not great, but looks enough good.
Try to replicate the tubes and cables.
This is going to be great
I see you know what you are doing with electronics...breadboard and resistors and such.
I wish I had more time for doing more builds with LED's as they are so versatile now.
I will shut up and watch now :pop:
JoaquinGM
Spain
Post by JoaquinGM »
Twokidsnosleep wrote: Wed Oct 10, 2018 7:06 pm This is going to be great
All electronic that I know, I learned in youtube. It's very basic and there is a lot of videos about leds and Arduino.
All your comments are welcome, I post to share, comment, discuss with all of you. :)
kiwigav
New Zealand
Post by kiwigav »
Nice Detailing Mate :th:
Cheers Gav
JoaquinGM
Spain
Post by JoaquinGM »
Han solo bed
shortCummins
Post by shortCummins »
looks really good so far
rgds
John(shortCummins)
Great work so far - really enjoying watching this come together.
JoaquinGM
Spain
Post by JoaquinGM »
Thanks for the cheering. :)
The Making of: The engine
This is a reference picture
First attempt: Fail. The heat drestroy the fiber.
I want to use fiber optics to make the pipes glow.
Second attempt: Good
A little of styrene and aluminium wire.
Also I finished the crew room. Need to paint it.
I Added 2 leds to make the engine bright
Looks good :th:
Ok that's pretty cool
Really enjoying this
JoaquinGM
Spain
Post by JoaquinGM »
Testing the warning red lights
You can see the Arduino board (horizontal) and the bluetooth board (vertical)
The RGB led inside the black rubber tube and the fibers optics.
For the RGB led: 3 wires (-5, grnd, data) for input, and 3 wires of output to connect the next led
and the result
With the RGB leds I can regulate the color and intensity. by example:
JoaquinGM
Spain
Post by JoaquinGM »
Doors
I need 2 doors for the interiors
I am going to use Oyumaru to make copies of the cabin door.
To use Oyumary paste, you need to heat it with hot water.
The mold
I made 3 copies. One with styrene and two with milliput.
I will used the "milliput" ones, are better.
JoaquinGM
Spain
Post by JoaquinGM »
Electronics: Sound and motor lights
First test: Fail :x
Once everything was wired and the system tested, I found several problems:
  • The speaker that I bought is very small 2.5cm and does not reproduce well the bass. This has an easy solution, I'm going to catch another bigger one.
  • The microprocessor does not have enough power to read and transmit the audio file from the SD card to the amplifier. So micro-cuts are heard and the audio quality is very low.
  • The LED strip interferes with the sound. The library of the LED strip uses microinruptions to send the data to the LEDs and this makes it interfere with the sound.
So I changed my strategy.
I used this mini DFPlayer module which is basically an MP3 player and combined SD card reader and does not even reach € 2 on Aliexpress.
In this way the microcontroller does not have to do the work of reading from the SD card and pass all the audio to the speaker, work that overloads it, but this module does it directly independently. The microcontroller will only tell you "play track 1" and the module takes care of everything.
Then the second test: Succeed! :lol:
This is the Fritzing schema of the board.
Ok WOW :jd:
Gary30
Post by Gary30 »
I LOVE this! More more more...... :clap: :clap: :clap:
Portfolio
Click here
JoaquinGM
Spain
Post by JoaquinGM »
Gary30 wrote: Mon Oct 22, 2018 9:03 am I LOVE this! More more more...... :clap: :clap: :clap:
Twokidsnosleep wrote: Mon Oct 22, 2018 3:30 am Ok WOW :jd:
Thanks! :thumb1:
This is the easy part, now I come back to scratch building. :?
JoaquinGM
Spain
Post by JoaquinGM »
I painted the floor and looks better.
JoaquinGM
Spain
Post by JoaquinGM »
Ramp
I'm going to adapt the ramp of the kit to fits inside.
JoaquinGM
Spain
Post by JoaquinGM »
Millennium Falcon couch
What a mess!!
Primer and fiber optics
Painted
Weathered with oils
JoaquinGM
Spain
Post by JoaquinGM »
I heard that the SW models were built from other kit pieces.
This is clearly from a German tank.
JoaquinGM
Spain
Post by JoaquinGM »
Control board
I used a F14 photoetch dashboard for the control board
I ordered some 3d printed models. 2 chairs
Guys, you can comment, critique, etc... 😉
Kingdan
Post by Kingdan »
:jd: :jd: :jd: :jd: wow
Fridgy
Post by Fridgy »
I'm just watching in speechless admiration
Mick
WIP: 1/12 Bandai BB-8 & R2-D2
JoaquinGM
Spain
Post by JoaquinGM »
Fridgy wrote: Wed Oct 31, 2018 5:01 am I'm just watching in speechless admiration
@Kingdan @Fridgy
Thanks for comment, but I'm sure you find something to enhance, this helps me to improve.
Pretty cool
Love seeing you put this together all out of your head and hands :thumb1:
JoaquinGM
Spain
Post by JoaquinGM »
The Main room
I inserted the door that I duplicated the other day.
It's time to work with styrene again.
General overview of the room, it need a lot of work, but it start to look as must.
Comments, critiques and suggestions are welcome. 😊
JoaquinGM
Spain
Post by JoaquinGM »
The table
I drilled some holes 0.3 mm for 0.25mm fiber optics.
It was a nightmare to paint the checkboard.
JoaquinGM
Spain
Post by JoaquinGM »
More electronics
I soldered all components in a board
The left to right: Arduino, MP3 player, Bluetooth communication.
This is my first time soldering a board.
I am not proud of this.
The second board was better.
This is the placement of all components inside the model.
Testing if all works.
I still have to synchronize the sound with the light, but now that I have everything on the boards, it is much easier.
This is just awesome!
You realise we're expecting the holographic chess pieces as well don't you :lol:
JoaquinGM
Spain
Post by JoaquinGM »
Tomcat64 wrote: Tue Nov 06, 2018 11:49 am This is just awesome!
I've been thinking about this :crazy: , but I still do not have a solution. ;) :lol:
Thanks for your words!
Very cool!
JoaquinGM
Spain
Post by JoaquinGM »
Exterior Lights main test
I can control the group lights with the mobile.
I need to organize the cables better.
Critique and comments are welcome.
JoaquinGM
Spain
Post by JoaquinGM »
Sync lights and sound
Main board
JoaquinGM
Spain
Post by JoaquinGM »
More Update
Love the chess table and seating.
Glad to see you are still plugging away at this :thumb2:
JoaquinGM
Spain
Post by JoaquinGM »
Tazman3 wrote: Thu Dec 13, 2018 3:27 pm I have really been enjoying this build, your ideas are spot on, and so I'm not even in your league as far as building expertise goes...but I would like to offer an idea for the hologram chess pieces...print them on clear acetate sheet, arrange them in different directions, and light from below...paint the top edge of each piece black, so the light doesn't bleed out. It might work, or maybe the idea will spawn another and a solution! Who knows! Just fabulous work...I just love this project.
Thanks for your comment, It's a good idea. I am not sure if I going to build the figures or how, but again thanks for your apportation. :thumb2: :thumb2:
JoaquinGM
Spain
Post by JoaquinGM »
Twokidsnosleep wrote: Thu Dec 13, 2018 4:56 pm Love the chess table and seating.
Thanks for your comments.
This project is burning me a bit :wtf: , it's too long. But I keep going, I need to finish this.
Missed the last couple of updates but that's looking superb :clap:
Just keep chipping away at it at your own pace - it's great!
Return to “Sci-Fi”
