Tomcat's 1/48 Eduard Saab J35F Draken
My second entry to the 1/48 drop in will be Eduard's Saab J35F Draken.
Here's the extensive background courtesy of the kit instruction book along with some photos I've picked off the internet along with one of my own :)
Overview
Introduction
There are not too many countries with the ability to develop a supersonic fighter. Sweden has belonged to this elite group from the very start of the supersonic era thanks to the Saab (Svenska Aeroplan AB) company founded in 1937. By the dawn of the jet era, Saab only developed three production piston engine aircraft. These were the reconnaissance/light bomber B17, the medium twin engine bomber B18 and the J21 fighter, which was later developed into the first Swedish jet, the Saab J21R. But the plane with the real impact on the jet era was the J29 Tunnan, the first production western jet with a swept wing. This was achieved thanks in part to access to German wartime aerodynamic research data. The Saab J29 Tunnan made its maiden flight in September 1948 and was produced in fighter and fighter-bomber versions.
Saab J29 Tunnan
A demand for more effective and more powerful air-to-ground abilities, as well as the need for an all-weather interceptor, led to the development of the Saab 32 Lansen. The Lansen was the first Swedish aircraft capable of reaching sonic speeds, although it was only a transonic, not a supersonic, aircraft. The supersonic era was entered with its successor, the J35 Draken.
Saab J32 Lansen
When defining their first supersonic aircraft requirement, the Swedish Air Force did not leave out the doctrine of the versatility of multiple take-off and landing areas using parts of highways and other suitable roads and strips. Also required was the ease of maintenance, and a refuelling and re-arming turnaround time of ten minutes in the field. This, in itself, places high demands on designers, who, led by Erik Bratt, decided to use a delta-wing concept. Some of the drawbacks of this configuration were solved with an innovative ‘double-delta’ wing with different angles along the leading edges: the inner section with 80-degree sweep and outer section with 57-degree sweep. The inner section is an integral part of the fuselage and, alongside the air intakes, it houses many of the aircraft devices.
The double delta wing was a very revolutionary concept, so it was decided a scaled down test model, the Saab 210 Lilldraken (Small Dragon), should be built. Only after 1,000 flying hours of testing, when aerodynamic calculations were confirmed, were the first three Draken prototypes ordered. The first one made its maiden flight on October 25th 1955, powered by an engine without afterburner. The second prototype followed and thanks to the installation of an afterburner, it broke the sound barrier for the first time.
Saab 210 Lilldraken
The first pre-production plane made its maiden flight on February 15th 1958. It began a production run of ninety J35A (Adam) aircraft. These Drakens were powered by a Rolls-Royce Avon 200 with 67 kN of thrust and armed with two 30mm ADEN M-55 cannons with 150 rounds per gun. Also, up to four Rb-24 (AIM-9 Sidewinder) missiles could be carried. The first J35A entered service during 1960.
Saab J35A Draken
The last 25 ‘Adams’ manufactured had a lengthened rear part of the fuselage due to a change in the afterburner chamber from the Type 65 to the Type 66. They were also equipped with a retractable double tail wheel to allow pilots to perform short take-offs with a nose high attitude without running the risk of damage to the rear part of the fuselage caused by contact with the runway surface. Both mentioned upgrades became standard on the J35B (Bertil) version with 89 aircraft produced. The ‘Bertil’ solved a great disadvantage of the preceding ‘Adam’, as the latter was only a day/good weather interceptor capable of only rear hemisphere attacks. New for the J35B was the S-7 fire control system and the domestic PS-03 radar, allowing head on attacks as well. The combat value of the Draken was raised by the possibility of carrying a wider variance of ordnance, including air-to-ground unguided Bofors 135mm rockets, unguided air-to-air 75mm rockets and also a variety of bombs up to 500kg.
Saab J35B Draken
The development of the Draken proceeded through the two-seater J35C (also known as the SK35C) to the more powerful J35D (David). More power came from the RM-6C engine with a maximum thrust of 76.81kN. As the engine needed more air, the intakes were changed. More fuel was also required, so the internal tanks were enlarged by 600l. The firing system was upgraded to the S-7A type. The prototype of the J35D took off for the first time on December 27th 1960 and 91 ‘Davids’ were manufactured. The J35D was the first Draken capable of reaching speeds over Mach 2, while its predecessors only managed Mach 1.8. From the J35B, a reconnaissance version designated S35E (Erik) was developed. Instead of radar, OMERA Ska-16B and KSa-24 cameras were installed in the nose. This Draken also sported a new, one-piece canopy.
Saab SK35C Draken
The ultimate version of the Draken was the J35 (Filip), powered by an RM6C engine with 78.48kN of thrust. The ‘Filip’ got a more convex, one-piece canopy than the S35End upgraded firing system capable of firing radar-guided Rb-27 missiles (Hughes GAR-3A Falcon) on fuselage pods and infra-red guided Rb-28 (Hughes GAR-4 Falcon) missiles. The firing system was supplemented by an S71N IR sensor. As the take-off weight rose with the ‘Filip’ version, the left cannon was deleted. The J35F was the most numerous of all versions, with 208 being built, first appearing with units during 1965.
Saab J35F Draken
The J35F Draken became the base for further development of avionic equipment, which led to the modification of 66 aircraft to the J35J (Jens) standard. They were introduced at the time when the Swedish Air Force was completing the transition to the J37 Viggen as a stop-gap solution until the new JAS-39 Gripen became available. The only user of the ‘Jens’ was F-10 Wing from Angelholm flying the type until December 1998.
Saab J35J Draken
With the Draken the Swedish aerospace industry recorded some export successes. The first buyer was Denmark, ordering 46 J35XD (Export Denmark) Drakens in 1968. These aircraft had 40% more fuel capacity, strengthened body and modified outer part of the wing. Danish Drakens were also capable of carrying unguided AGM-12 Bullpup air-to-ground missiles. The Danish Air Force flew them until 1993.
Finland
Another user of the Draken was Finland, ordering twelve J35XS (Export Suomi) aircraft. These were supplied in parts and assembled by the Finnish Valmet company in 1974 and 1975. The J35XS was similar to the J35F, but had both cannons. Some changes to the avionics and the deletion of the Falcon missile guidance system were also differences in this version. Finland later (1976) bought six used J35FS plus three J35CS and 18 more in 1984. Altogether Finland used 48 Drakens, flying them until 2000.
Austria
The Austrians bought their Drakens in 1985. They were originally J35Ds upgraded by Saab to J35OE standard. Modifications were made to the navigation systems and avionics, and the aircraft also sported the canopy from the J35F. Originally, the J35OE was armed only with cannon, as an agreement of the Allied powers from 1955 forbade Austria from operating any military missiles. This agreement was passed over with silence after some incidents during the war in the former Yugoslavia and Austrian Drakens got the go ahead to carry AIM-9 missles. The J35OEs were used until 2005, becoming the last of the Drakens in active service.
Onto the kit - this will be the first 1/48 Jet I've built since joining the forum so it's going to be a bit of a voyage of discovery...
Kit
I picked this up in 2016 and it's been lurking in the stash ever since
Here are the styrene parts from the Hasegawa donor kit
Decals and some of the PE from Eduard
More PE and resin from the kit itself along with some missiles that I added to the stash at some point
And finally the instructions
There are four schemes included in the kit but I'll most likely go for this one as I like the red tail with the ghost
Although I was slightly torn by the Finnish one as this was based somewhere we've visited - Just have to get another one :)
Normally with aircraft I see the real thing first and then want to get a kit, but in this case it was the old Airfix kit that I saw first & fell in love with the shape of the aircraft as well as the fact it was an unusual blue & green colour scheme. I revisited that childhood kit a couple of years back and this is how it turned out in 2019
I still love the double-delta shape of the Draken and think it looks futuristic despite first flying in the late 1950s.
Re: Tomcat's 1/48 Eduard Saab J35F Draken
Holy smokes Batman, TC's gone and got himself a JEEEEEEET!
Time to pull up the comfiest of chairs, wheel out the portable toilet and settle in for the ride :pop:
Stokesy44 wrote: Fri Aug 12, 2022 6:46 pm Holy smokes Batman, TC's gone and got himself a JEEEEEEET!
:lol: :lol: :lol:
Good to have you along for the ride as always, Wing Commander! :cheers2:
Tomcat's 1/48 Eduard Saab J35F Draken - Build Part I
I had two good afternoons at the bench this weekend despite the ongoing heat and made a start on the Draken.
As seems usual with most aircraft the build starts in the cockpit, but since the cat forgot to order the paint all we could do for now was sand out the bits ready for the Eduard coloured PE to go in, and add the non-coloured PE
This included adding a couple of bits to the upper fuselage as well (looks like a little tidying up may still be in order)
Since I was still in the mood to make some progress with this I also assembled the nose-cone & added about 5g of Deluxe Materials Liquid Gravity and sealed it with CA. The instructions call out for 3g to avoid tail sitting but better safe than sorry I reckoned
I also drilled out the holes in the lower fuselage for the external tanks & assembled the outer wings and tail fin - since this is going to be mostly red my idea is to paint & mask this separately before adding it to the upper fuselage to hopefully make masking easier
That's all for now but happy to have another build under way :) Hopefully the paint will turn up this week so we can make more progress.
Thanks as always for looking :cheers2:
I was lucky enough to see both Drakens and Viggens over the Suffolk countryside in the 80's -The Viggen was a beast! Looking forward to seeing how this goes, good luck with the build :pop: :thumb2:
Looking good! :th:
Quax wrote: Sun Aug 14, 2022 7:46 pm I was lucky enough to see both Drakens and Viggens over the Suffolk countryside in the 80's -The Viggen was a beast! Looking forward to seeing how this goes, good luck with the build :pop: :thumb2:
I got to see both at the Farnborough airshows. The Draaken looked fast even on the ground and in the slow fly-bys but the Viggen display will forever be etched in my mind. Come the slot for the Viggen you could hear engines spooling up but no sign of the plane on the runway or taxiway. The commentator said "SAAB are pleased to present the AJ37 Viggen" and as he finished a cam net in the trees at the Aladins Plain end of the runway was pulled aside and a Viggen in tri-tone cammo came barrelling out from between the trees with the fin folded but coming up. As it turned onto the runway the fin locked in and the pilot hit full throttle + reheat. After one of the shortest take off runs that day it did something I'd only ever seen EE Lightnings do before - stand on its tail about a planes lenght above the runway & go into a vertical climb.
To me the Draaken always said "Elegance" and "Scalpel" - and the build seems to capture all this whereas the Viggen said "Lumpy" and "Hammer". Kind of like the Swedish interpretation of the A-10.
    ForeverPlasticKits
    France
    Post by ForeverPlasticKits »
    I have this kit in the stach, i think i really enjoy your build specially with the add ons. And the story of the plane, excellent idea! :thumb1: :thumb2:
    Parker
    Post by Parker »
    stunning jet!
    On The Bench (Dining Table) - CF-104 Starfighter
    aur0ra145 wrote: Sun Aug 14, 2022 11:02 pm Looking good! :th:
    RangerNeil wrote: Tue Aug 16, 2022 11:34 am I got to see both at the Farnborough airshows. The Draaken looked fast even on the ground and in the slow fly-bys but the Viggen display will forever be etched in my mind. Come the slot for the Viggen you could hear engines spooling up but no sign of the plane on the runway or taxiway. The commentator said "SAAB are pleased to present the AJ37 Viggen" and as he finished a cam net in the trees at the Aladins Plain end of the runway was pulled aside and a Viggen in tri-tone cammo came barrelling out from between the trees with the fin folded but coming up. As it turned onto the runway the fin locked in and the pilot hit full throttle + reheat. After one of the shortest take off runs that day it did something I'd only ever seen EE Lightnings do before - stand on its tail about a planes lenght above the runway & go into a vertical climb.
    ForeverPlasticKits wrote: Tue Aug 16, 2022 8:32 pm I have this kit in the stach, i think i really enjoy your build specially with the add ons. And the story of the plane, excellent idea! :thumb1: :thumb2:
    Parker wrote: Wed Aug 17, 2022 1:53 am :pop:
    stunning jet!
    Thanks for dropping in everyone :cheers2:
    I was always happy to see these things at airshows in the 80s & early 90s and as with most things wish I'd been paying more attention back then as we rarely knew when we might be seeing something for the last time.
    The Swedish Air Force Historic Flight have a great collection and I really hope a way can be found for them to show off over here again.
    Tomcat's 1/48 Eduard Saab J35F Draken - Build Part II
    Just a couple of photos for this update but there's been quite a bit of work as the paint for the cockpit turned up so that was deployed and then it was a bit of a PE party for a few hours :)
    And a quick dry fit showed that everything could still be crammed in and squished together successfully
    I now need to figure out if/how I want to weather the cockpit as I think these things did get quite scuffed up in service so I'll do a bit of research before buttoning everything up.
    That's all for this one - thanks as always for looking :cheers2:
    Cockpit looks very tidy. Nice work Sir :clap: :clap:
    Very nice progress so far! I have this same kit at home and may need to break it out when I get home from this work trip.
    ForeverPlasticKits
    France
    Very good start! :thumb1: :thumb2:
    Stokesy44 wrote: Sun Aug 21, 2022 8:14 pm Cockpit looks very tidy. Nice work Sir :clap: :clap:
    aur0ra145 wrote: Sun Aug 21, 2022 9:00 pm Very nice progress so far! I have this same kit at home and may need to break it out when I get home from this work trip.
    ForeverPlasticKits wrote: Sun Aug 21, 2022 10:52 pm Very good start! :thumb1: :thumb2:
    Thanks chaps - I did a bit of research :eeek: and realised the rear wall of the cockpit should actually be aluminium so I'll mask that off & respray it at some point this week all being well.
    cor
    Post by cor »
    The cockpits looking nice.
    cor wrote: Mon Aug 22, 2022 1:49 pm The cockpits looking nice.
    Thanks mate :cheers2:
    Tomcat's 1/48 Eduard Saab J35F Draken - Build Part III
    This turned up this week
    Which interestingly included this photo & illustration :)
    So it seemed appropriate to tackle the tail plane - this was undercoated in Ultimate Gelb primer followed by several thin coats of Vallejo model air reds (actually Ferrari red followed by red). This was left overnight and then masked up to allow the metallic leading edge to be painted
    While I was waiting for paint to dry on this and other projects I hacked the ejection seat off the casting blocks... I don't know if it was harder resin than I'm used to or if my saw is getting blunt but I managed to break the seat with some inappropriate handling... :bash:
    Anyway it was all resolved with a generous helping of CA - this has since been primed & is ready for painting
    The cockpit was scuffed up a bit & given a coat of Ammo Neutral Wash
    And then sealed into the fuselage halves along with the nose cone, there is a slight join to deal with but nothing too serious
    So the outer wings were added and that classic shape appears, again there are some minor joins to tidy up once the TET is set
    And with that done I used a couple of other subassemblies to get an idea of how it was going to turn out...
    This is now the only project on the bench so hopefully I can crack on and make steady progress
    Looking good - the vertical stabiliser has turned out really well. Did you weight the nose at all for the under carriage?
      That AM ejection seat loos proper nifty. Should look great in the pit
      RangerNeil wrote: Mon Aug 29, 2022 7:47 pm Looking good - the vertical stabiliser has turned out really well. Did you weight the nose at all for the under carriage?
      Stokesy44 wrote: Mon Aug 29, 2022 9:29 pm That AM ejection seat loos proper nifty. Should look great in the pit
      Thanks chaps :cheers2:
      Yep there's about 5g of weight stuffed into the nose, the instructions call for 3g but I erred on the high side since there was space for the extra.
      Nice cockpit :th:
      Those are wicked mean looking aircraft :thumb2:
      Twokidsnosleep wrote: Wed Aug 31, 2022 5:28 am Nice cockpit :th:
      Thanks mate - I love the shape of these things :)
      Tomcat's 1/48 Eduard Saab J35F Draken - Build Part IV
      Not a huge amount of progress to report but I have been pottering away on this...
      The rear jet-pipe housing was put together
      And then I noticed that the joker that wrote the instructions reckons I should stuff a couple of PE rings up there...
      Not convinced how much will be visible once the pipe is in place
      But being game for a laugh I deployed the mini-pegs & CA - oh, and judicious amounts of swearage
      And got them in, slightly wonky in a couple of places, but definitely in there :)
      The tightened opening meant the guides on the jet pipe need a couple of swipes with a sander
      And how much can be seen...
      Aaah well... what are Sunday afternoons for...
      Back to the main chunk and the various joins have been filled & more components (visible ones at that) have been added :)
      I've also made a start on painting up the ejector seat so hopefully will have that finished this week all being well, then I guess it's onto the under-danglage
      Firmly going going forward and looking great.
      digger303 wrote: Mon Sep 05, 2022 11:36 am Firmly going going forward and looking great.
      Tomcat's 1/48 Eduard Saab J35F Draken - Build Part V
      Been picking away at this one whilst figuring out what I want to do with the banshee...
      First up the engine housing & jet pipe were given a coat of Ultimate Black primer followed by a couple of layers of Vallejo Exhaust Manifold; the afterburner injector was given a steel coat to add a little contrast
      It looks a little scruffy like that, but once assembled it works ok as most of it is hidden away
      With that done the housing was attached to the back end of the fuselage
      I've also plugged away adding the belts to the bang-seat, not entirely happy with my PE work here but it's getting there
      I had to sand an angle into the seat base to get it to lay flat against the bulkhead as it shows in reference photos
      So a little tidying up, add the decals & a wash and that will be that done.
      Underneath I added the strakes and couple of fins to knock off during painting - the remaining locator holes are for weapons pylons so this is just about ready to start painting up
      I've also nibbled out the small chunks ready for the nav lights which are supplied as clear parts in this kit
      And added the tail fin :)
      So I'll keep pottering away at the seat, and then move onto the final cockpit details such as the HUD & glazing and the airframe will be ready for priming top & bottom
      Seat harness looks good.
      Very cool shaped aircraft. Looks fast just sitting there.
      Like a Ford Capri! :lol: :lol:
      Very slick looking craft. With all the bits you have been working on, I'm betting it will come together quite quickly soon.
      Stokesy44 wrote: Thu Sep 15, 2022 7:29 pm Seat harness looks good.
      I wonder if it needed a concrete block in the boot to corner properly like the Capri did... :think:
      digger303 wrote: Fri Sep 16, 2022 12:50 am Very slick looking craft. With all the bits you have been working on, I'm betting it will come together quite quickly soon.
      Tomcat's 1/48 Eduard Saab J35F Draken - Build Part VI
      I decided to give this one some attention on the bench this weekend...
      First up although there were cockpit masks included in the kit I forked out on an extra set which included the interior masks as I intend to pose the lid open on this one so wanted to make sure the frames were properly painted and couldn't be bothered to work out the masking myself :)
      The two part canopy masked up inside & out with some additional Tamiya tape to fill in the gaps
      With the windscreen interior frame painted up I removed all the masking to make sure it sat right and that there was sufficient clearance for what I had in mind
      And what I had in mind was adding the two internal struts that are quite a distinctive feature on the Draken which both Hasegawa & Eduard don't include. These were made up of thin brass rod painted up appropriately and set with PVA
      Then trimmed back to length
      Test fitted & all still ok (although it needed dusting!)
      The HUD & a couple of other cockpit instruments from the PE fret were added
      The ejector seat had been given a grimy wash and was just dry fitted - but all fitted ok
      A final check with the modified windscreen
      Then the windscreen was remasked using the kit masking set and both parts tacked in place with PVA
      Here's a multi-media collection with the resin wheel set from the Eduard box alongside the drop tanks from the kit in styrene - all cleaned up & awaiting their next phase
      And finally for this update the nose-gear assembly & turbine (RAT?) were built up and set aside.
      Next the main gear legs will be built up and I'll start adding the metallic colours to the underside, wheel bays & leading edges.
      Very nice detail work on the windscreen. Ready for some paint now
      Excellent addition to the cockpit canopy
      That will make a huge difference in reality
      Very nice so far and agree with Scott that, sometimes, its those little details that are the most satisfying when the kit is done and dusted.
      cheers
      Stokesy44 wrote: Mon Sep 26, 2022 2:38 am Very nice detail work on the windscreen. Ready for some paint now
      Twokidsnosleep wrote: Mon Sep 26, 2022 3:36 am Excellent addition to the cockpit canopy
      Quax wrote: Wed Sep 28, 2022 3:20 pm Very nice so far and agree with Scott that, sometimes, its those little details that are the most satisfying when the kit is done and dusted.
      cheers
      Thanks for dropping in chaps :cheers2:
      Tomcat's 1/48 Eduard Saab J35F Draken - Build Part VII
      So after a bit of a hiatus due to the usual reaons (work, busy weekends, forgetting to order paint) I've managed to get back to the bench on a couple of evenings this week.
      The main gear legs were assembled and fiddly PE installed
      I primed the ventral section of the fuselage in Ultimate black in preparation for the metal sections and then realised two things... 1. the tail wheel bay doors & assembly should also be installed as they're also the same metallic colour and 2. I hadn't ordered the metallic paint I wanted to try here...
      So here's the rear mini-wheel bay installed
      And then finally onto some paint - the metallic sections were a three part job; first a layer of Ultimate Black, then a layer of Vallejo Metal Color Steel and finally a couple of layers of Metal Color Duraluminum... here are the drop tanks - nice & shiny :)
      The same approach applied to the ventral fuselage, wheel bays & wing leading edges - there's a teeny tiny seam line towards the rear of the fuselage which obviously didn't show up under the black or steel but went :nena: as soon as I laid down the bright top coat... anyways it's down the back & underneath so I'm going to leave it as I'm pretty sure I'd screw things up trying to fix it
      The landing gear legs, wheel hubs & wing pylons have all had the same treatment.
      So with that done I'll leave it to dry thoroughly before masking up & starting on the camo colours - we're away again this weekend so that'll be something for next week all being well.
      Thanks for looking :cheers2:
      ForeverPlasticKits
      France
      Amazing result from your huge work on this beautiful kit! :thumb1: :thumb2:
      Beautiful painting.
      The PE on the undercarriage looks superb. Another class winner on your hands Sir? :whistle:
      ForeverPlasticKits
      France
      Superb! :thumb1: :thumb2: :clap:
      Stokesy44 wrote: Sat Oct 15, 2022 7:57 am Beautiful painting.
      ForeverPlasticKits wrote: Sat Oct 15, 2022 7:36 pm Superb! :thumb1: :thumb2: :clap:
      I'm really happy with the way that the metallic section turned out so just hoping that the masking I have to do next doesn't rip it up...
      Tomcat's 1/48 Eduard Saab J35F Draken - Build Part VIII
      ...talking of masking all the metallic sections were masked off - the bulge towards the back end is where I've packed some foam around a fin to try and protect it when I pull the tape back off
      With that done the undersides were given a coat of Ultimate black followed by ModelAir Dark Gull Grey & a mist of Light Gull Grey
      That was left to dry overnight before masking ready for the upper surfaces - there was a curve in the demarcation line either side
      Which was done by using a circle cutter & scalpel to chop into quarters and then align onto the previously laid tape sections
      Then the rest of the underside was masked off using tape & plain paper
      The topside was then given a coat of Ultimate grey primer
      And finally for this update a coat of Vallejo US Olive Drab
      I'll let that settle in and then mask it ready for the dark blue.
      smokeriderdon
      Post by smokeriderdon »
      One of my favorite non U.S. planes. Looking great!
      Lovely paint work and I want one of those cutting doohickeys too :th:
      smokeriderdon wrote: Sun Oct 23, 2022 6:14 pm One of my favorite non U.S. planes. Looking great!
      Stokesy44 wrote: Sun Oct 23, 2022 7:28 pm Lovely paint work and I want one of those cutting doohickeys too :th:
      Thanks guys - after the paint dried I noticed a rough area where I'd done some seam sorting down by the port nose section so I'll need to tidy that up as it'll just keep bugging me otherwise
      Very cool! There are a few planes that have stuck in my head since I was a kid: F-111, EE Lightning, and the Draken! I have the first two as kits but not this one yet.
      :thumb2: :thumb2:
      ForeverPlasticKits
      France
      Very beautiful paint! :thumb1:
      DBMiller wrote: Tue Oct 25, 2022 9:03 pm Very cool! There are a few planes that have stuck in my head since I was a kid: F-111, EE Lightning, and the Draken! I have the first two as kits but not this one yet.
      :thumb2: :thumb2:
      ForeverPlasticKits wrote: Tue Oct 25, 2022 10:52 pm Very beautiful paint! :thumb1:
      Thanks guys :cheers2:
      Tomcat's 1/48 Eduard Saab J35F Draken - Build Part IX
      I've grabbed the odd hour here & there to make some more progress with the Draken
      The undercarriage is done and just needs a little weathering on the tyres
      Then once I'd sorted out that annoying patch of paint I mentioned previously it was time for masking...
      This was followed by a light coat of Ultimate grey to give a neutral undercoat, and then the jetpipe housing was sprayed with Vallejo USN Dark Blue
      The USN Dark Blue is supposed to be the FS colour match to the blue-grey camo colour but I'm not sure it looks right so when I get chance I'll mix something up and see how that goes.
      That's all for now - really slow progress at the moment but thanks for looking :cheers2:
      That's some epic masking there Sir.
      You must have been gasping for a stiff drink after all that! :o
      some incredible curvy masking going on there! :crazy: The undercart looks very good though!
